Windows updates - content filter (Firewall)
Hello there,
I have a problem with windows updates because of firewall categories - it used to work with Bussines and Software/hardware option enabled, right now its not enough. I tried to enabled all categories for test purposes and updates worked after that. I would like to skip testing by enabling categories one by one, so have you guys any tips which category is additionally responsible for blocked windows updates.
Thank you in advance
  • smb_corp_user
    smb_corp_user Posts: 172 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Unfortunately, I don't know the answer to your question, but I would like to suggest adding more information about your configuration, just in case it increases the chance someone will be able to help you find a solution. For example, knowing which Zyxel device (model & firmware version) you are using might make a difference to anyone wanting to help you find any working solutions.
    I have read some web pages from Microsoft support and learning forums regarding Windows Update and ports to allow through firewalls. Several Windows Update server pages/sites do not have static addresses, so a working solution would have to include using URL addresses instead of IP addresses, as well as firewall support for address wildcards (asterisks, * ).
    I can only wish you best of luck with your efforts and in getting help from other forum members.
  • JAnkostik
    JAnkostik Posts: 2
    It is USG FLEX 500
    Firmware Version
    V5.38(ABUJ.0)
    Thanks, i tried those URL sites ( all of them were included in mentioned categories ) and still not succesfull :/
  • WJS
    WJS Posts: 156 image  Master Member
    edited June 2024
    I'd like to use APP patrol instead. Here is App category named: Windows upgrade.
    or follow PeterUK instruction setup blocklist on CF lists
