How to block "hacker" ip if exist NAT rule
Hello.
1 Device - USG FLEX 200
2 We have NAT rule - 1234 external port to local x.x.x.x ip, 4321 local port service "RDP"
3 "Hacker" is brute this port from y.y.y.y.
Q:
USG is block y.y.y.y after 3 attempts, and unblock later, block again and unblock later :)
How create permanent rule for blocking y.y.y.y or y.y.y.y.y/24
Make a Policy Control with new object address y.y.y.y for the source and action deny
Certainly, Policy was created after create nat rule. Priority -1 in policies.
Ip object was created, very uncomfortable create rules and object :) for each network.
Policy rule created and active, Source - Address Group
and
P.S.
I off policy log option after create image.
You can create an IP group that includes the blocked IP addresses(I mean y.y.y.y or y.y.y.y.y/24), and then create a security policy to block those IPs from accessing your public IP.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
