Unable to reach port
Hello
i have fowarded 3 ports on 3 internal ip (PC) , i have already created also the policy from wan to lan1 to manual ip.
For 2 are ok but one give me a error
It was a similar streaming from outside to inside, if i see the log i see this
Time | Category | Message | Src. IP | Src. Port | Dst. IP | Dst. Port | Note | Action |
2024-06-11 19:27:17 | Security Policy Control | Rule name:Sputnik, from WAN to LAN, TCP, service others, DNAT Packet, ACCEPT | xxx.xxx.x.xx | 53203 | 192.168.0.146 | 5111 | ACCESS FORWARD | Accept |
Whats's wrong? Thanks
What your forwarding to might not be TCP?
log show its forwarded what saying its its not?
Hello, because the streaming not arrive to server.
This is i make:
Create a services with ports and add to group
Then add the nat ( i try virtual server and 1:1 NAT)
And the policy
The log
I try all that i know. Some help?
The Device is USG FLEX 100H
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
