How to block "hacker" ip if exist NAT rule
Pavel
Pavel Posts: 112 image  Ally Member
Hello.
1 Device - USG FLEX 200
2 We have NAT rule - 1234 external port to local x.x.x.x ip, 4321 local port service "RDP"
3 "Hacker" is brute this port from y.y.y.y.
Q:
USG is block y.y.y.y after 3 attempts, and unblock later, block again and unblock later :)
How create permanent rule for blocking y.y.y.y or y.y.y.y.y/24
    PeterUK Posts: 4,272 image  Guru Member
    Make a Policy Control with new object address y.y.y.y for the source and action deny
  • Pavel
    edited June 2024
    Certainly, Policy was created after create nat rule. Priority -1 in policies.
    Ip object was created, very uncomfortable create rules and object :) for each network.
    Policy rule created and active, Source - Address Group
    and
    P.S.
    I off policy log option after create image.
  • MJStar
    MJStar Posts: 37 image  Freshman Member
    First Answer First Comment Friend Collector Fourth Anniversary
    You can create an IP group that includes the blocked IP addresses(I mean y.y.y.y or y.y.y.y.y/24), and then create a security policy to block those IPs from accessing your public IP.
