USG FLEX 200 - SSL VPN and 2FA Authenticator App
AdmineXant
AdmineXant Posts: 12 image  Freshman Member
Can anyone answer the question whether the new USG FLEX 200 supports 2-Factor authentication when connecting SSL VPN using, for example, the authenticator application like Google Authenticator or Microsoft Aythenticator?
    PeterUK Posts: 4,268 image  Guru Member
    edited June 2024
    Maybe I'm missing something but I can't get Google Authenticator to work with SSL or IPSec VPN Access it works fine by Email
    Your meant to go to Authorize Link URL Address put in the Google Authenticator code but it don't work? on a Flex200…
  • AdmineXant
    edited June 2024
    What I meant was whether USG FLEX 200 supports 2FA for normal SSL VPN users. I can't find this information elsewhere. I would like to provide acces to company VPN with Google Authenticator as a 2FA.
    On my old ZyWall 110 i could run Google Authenticator only for admin when login to zywall GUI but for vpn was only e-mail link as a 2 factor auth .
    Yes I tried USG FLEX 200 for 2FA for Google Authenticator on SSL VPN users I could not get it to work only by Email
    I could only get Google Authenticator for admin when login to zywall GUI to work
  • AdmineXant
    Zyxcell support answered my question directly:
    For the USG FLEX series, it is possible to configure 2FA with GA for regular users using SSL VPN connections.
    Here's a link to an article in our knowledge base that explains the configuration and connection steps:
    https://support.zyxel.eu/hc/en-us/articles/360001390774-VPN-Configure-SSL-VPN-via-SecuExtender-Stand-alone-mode
    must of worked at some point but not any more😓
