Zyxel USG Flex 500 Ports
HyungKim0105
HyungKim0105 Posts: 10 image  Freshman Member
Zyxel Certified Network Administrator - Security First Comment
Im trying to utilize the SFP port on our Firewall. would it be possible to assign SFP port in same lan group as other ethernet ports? So I basically need 1 Wan port and 7 Lan ports. I'm kinda short 1 port so I was wondering if that was possible.
Thank you.
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    SFP Port can act as LAN Port, but it cannot become the same lan role with other Lan
    As you saw in "Port role", SFP Port is independent.
  • WJS
