SSL don't works
T_G
Hello
i'm tryng to set ssl vpn
I have
- add in service Default_Allow_WAN_To_ZyWALL ssl service
- add user and group
- Add a rule in policy control: from wan to zywall, service sslvpn any allow
- generate a certificate
Then download the file but not work.
In openvpn tell me: connection timeout
The firewall is behind a router in dmz, other service ( portfoward and other service works)
can you port scan 10443 ?
https://www.grc.com/x/ne.dll?bh0bkyd2
Also as your behind another router the config file for IP will be wrong and you need to correct that when you download the SSL VPN config or put in a DDNS for DNS name
The problem was the ip
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
