CANNOT ACCESS Network > NAT at all
via the web interface Network > NAT never loads, all I get is spinny circle.
tried command line, cannot figure out how to delete any NAT rules, where is the command reference to delete a rule?
Hello @JPElectron
Please use the CLI "show config vrf main virtual-server rule" to check the current virtual-server rule, as shown below, the rule is named NAT.
usgflex100h> show config vrf main virtual-server rule
rule NAT
enabled true
interface ge1
source-ip any
original-ip address 10.214.48.38
map-to address 192.168.168.168
nat-1-1-map
false
nat-loopback
true
map-type anyIf you want to remove the NAT rule, please refer to below CLIs:
usgflex100h> edit running
usgflex100h running config# del vrf main virtual-server rule NAT
usgflex100h running config# commit
Configuration committed.0 -
Please refer to below FAQ articles:
How to check the NAT rule using CLI for USG Flex H series models?
How to remove the NAT rule using CLI for USG Flex H series models?
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
