SSL don't works
T_G
T_G Posts: 17  Freshman Member
Hello
i'm tryng to set ssl vpn
I have
  • add in service Default_Allow_WAN_To_ZyWALL ssl service
  • add user and group
  • Add a rule in policy control: from wan to zywall, service sslvpn any allow
  • generate a certificate
Then download the file but not work.
In openvpn tell me: connection timeout
The firewall is behind a router in dmz, other service ( portfoward and other service works)
    PeterUK Posts: 3,909  Guru Member
    edited June 2024 Answer ✓
    can you port scan 10443 ?
    https://www.grc.com/x/ne.dll?bh0bkyd2
    Also as your behind another router the config file for IP will be wrong and you need to correct that when you download the SSL VPN config or put in a DDNS for DNS name
  • T_G
    The problem was the ip
