USG Flex series: offline preparation is impossible?
mMontana
mMontana Posts: 1,432  Guru Member
So…
Having firmware file downloaded, having the future running configuration ready, having users prepared… Is possible to start a USG Flex device without any internet connection?
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,431  Zyxel Employee
    Hi @p4_greg & @mMontana,
    We still suggest all devices follow the wizard to register to myZyxel.com. I'll send the command to you in private message. Thanks!
    PeterUK Posts: 3,892  Guru Member
    Yes we really need to download the firmware my FLEX is having problems get to 1.20(ABWV.1)C0 I'm now trying a old firmware to then update
  • Zyxel_Emily
    Hi @mMontana,
    I sent the command to you in private message. Please check the message and enter the command on the device.
  • p4_greg
    p4_greg Posts: 29  Freshman Member
    Network Detective-New Adventure Badge First Comment Friend Collector Third Anniversary
    Can you please send me this secret command? Can you post it on the forum so that others can benefit from this information also?
  • mMontana
    edited June 2024
    IMVHO this command should be published as part of documentation. Due to sharing in private way, i won't share it here.
  • Zyxel_Emily
