LTE3301-PLUS - USG40
jonathanbeck68
jonathanbeck68 Posts: 4
edited June 2024 in Security
I have an LTE3301-plus (4G) connecting to the WAN port of a USG40. I want to establish an SSL VPN connection to the USG40.
I tried in normal mode NAT of port 443 on the LTE3301-PLUS and in passtrough ip (Bridge) mode, I have nothing displayed on the USG40 log.
I specify that the SSL VPN works when I attack the USG WAN port (connect to the LTE LAN port.
Do you have an example configuration that works?
Do I need to do any configuration on the USG when I switch LTE to bridge?
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    What's your IP address on USG40 WAN when LTE bridge?
    It should not work if you get CGNAT addresses (100.64.0.0~100.127.255.255)
  • Ip address for USG is Adresse IPv4: 10.132.228.175
    Masque de sous-réseau IPv4: 255.255.255.224
    Passerelle par défaut IPv4: 10.132.228.176
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 959 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @jonathanbeck68 ,
    The Address from ISP is Private IP which means it can be access from Internet.
    Thank you
  • OK thanks.
    I have never had any difficulty with NAT and SSL VPN behind a wired box.
    I guess it's because I'm not familiar with LTE3301-plus.
  • There is one thing that I don't understand, when I do a tracert (or a ping) from another network to the ddns, it does not succeed?
    C:\Users\jonathan.beck>tracert jonathanbeck.freeddns.org
    Détermination de l’itinéraire vers jonathanbeck.freeddns.org [10.131.59.53]
    avec un maximum de 30 sauts : 1 <1 ms <1 ms <1 ms 192.168.1.254
    2 1 ms * 1 ms 65.218.135.77.rev.sfr.net [77.135.218.65]
    3 6 ms 6 ms 6 ms 108.97.30.212.rev.sfr.net [212.30.97.108]
    4 * * * Délai d’attente de la demande dépassé.
    5 * * * Délai d’attente de la demande dépassé.
    6 * * * Délai d’attente de la demande dépassé.
    7 * * * Délai d’attente de la demande dépassé.
    8 * * * Délai d’attente de la demande dépassé.
    9 * * * Délai d’attente de la demande dépassé.
    10 * * * Délai d’attente de la demande dépassé.
    11 * * * Délai d’attente de la demande dépassé.
    12 * * * Délai d’attente de la demande dépassé.
    13 * * * Délai d’attente de la demande dépassé.
    14 * * * Délai d’attente de la demande dépassé.
    15 * * * Délai d’attente de la demande dépassé.
    16 * * * Délai d’attente de la demande dépassé.
    17 * * * Délai d’attente de la demande dépassé.
    18 * * * Délai d’attente de la demande dépassé.
    19 * * * Délai d’attente de la demande dépassé.
