XGS1210-12 V2: Compatible SFP10G-T Module
Hello Zyxel Team,
I am considering to purchase XGS1210-12 V2 and looking also for a compatible SFP10G-T Module. For example MikroTik S+RJ10.
But in one older discussion a user report that XGS1210-12 is not compatible with XGS1210-12. I am wondering if this has been improved in V2 version?
Alternatively, a list of compatible SFP10G-T module would be apperciated.
Here a non-china manufacturer is preferred.
Thank you.
Hi there,
In case you still want to use the SFP10G-T, please refer to Zyxel SFP10G-T.
Please note that SFP10G-T modules tend to generate more heat. Ensure you have a suitable method to maintain your switch at a normal temperature for proper operation.
Zyxel_Judy
Hi @Tactice ,
SFP10G-T modules tend to generate more heat due to high power consumption, and the XGS1210-12 V2 has a fanless design. Therefore, we do not recommend using the SFP10G-T with the XGS1210-12 V2.
For SFP10G usage, please refer to the recommendations below.
Detailed information can be found in the datasheet.
Zyxel_Judy
Hello Judy,
thank you for the answer.
My target connection is a NAS with SFP10G-T interface. There it is no possible to use glas fiber or other interface. But the usage of the switch is in a low load and cooler inviroment.
Which is the right SFP10G-T to use on with the XGS1210-12 V2?
GreetingsToni
Hi there,
Zyxel_Judy
Thank you.
Using cooling fins is one method I used to cool down the switch. It may be helpful for you guys.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
