ZyWALL ATP200 how to start with Vlan?
Username_is_reserved
Username_is_reserved Posts: 126 image  Ally Member
Here is my Network in a very simplified way:
The ATP (will) have 2 Wan Connection one slow DSL and one fast but unreliable Cable.
There are multiple Switch in the System 2 Zyxel and a Handfull Managed and Unmanaged one. I use an Netget for example for PoE to power the AP and some IP Phones.
I intend to have atlest 4 Vlans for: Guest, IP Phone, Business, Home stuff. Currently everything run on the old USG without a VLan.
So how to make it easy to Switch "just" the Lan cable from the old to the new Router?
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @Username_is_reserved,
    Greeting forum , this is my suggestion. I
    For exapmle : vlan 10 AP,vlan 20 IP phone,vlan 30 home stuff,vlan 40 Client
    1) All UPLINK of Switch using 802.1Q, and allow tag all vlan.
    I am not sure what's your AP level/topology.Maybe It should using 802.1Q on switch port which connect to AP  and tagging vlan10,30 .
    2) Setting the vlan on individual switch ports (vlan10 for AP,Vlan20 for IP Phone, etc.)
    -In order to look clean, you may also make switch port 1-6 vlan10,7-12 vlan20,etc . But you have to sort out the cable.
    3) Setting Vlan address on ATP200 ,(Assuming LAN2 Connect to internal switch)
    -These are VLANS Gateway , All traffic between vlan will pass through the firewall .
    Kevin
  • Username_is_reserved
    For example : vlan 10 AP,vlan 20 IP phone,vlan 30 home stuff,vlan 40 Client
    Kevin
    Thanks for replay. The are WAC APs.
    How to prevent that I cant access anything any more when I set a Vlan?
    I guess I must do a VLan Trunk when I setup the Switch?
    When the Switch in the Vlan 10 and the Guest connect to the Wifi AP the should get in there own Vlan (sry I got confused by my own Diagram) lets say Wifi Guest are Vlan 50...
    For the Guest I should activate: Layer 2 Isolation to I guess?
    Is there a good "How To" for the "Web Authentication"?
  • Zyxel_Kevin
    -Kindly using Mgmt Port to set up Switch to prevent loss connection.please notice you must need downtime to do the vlan change.
    -Yes, All uplink between switch must have  802.1Q .
    -The switch port which connect AP must have 802.1Q as well.
    -Yes, Layer 2 isolation in AP.
    -Please Kindly find our hand book (Page 571~576),
    Sorry everyone its still me. Now I want start to change. I see some Device like an IP Phone should support adding an Vlan ID. Should I add the Vlan ID there to?
    The confusing part is why the Vlan is part of the Zone/ Port?!
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    As far as I know, the vlan setup on sip phone is named voice VLAN with tagging. The purpose is to separate the voice stream and data stream.
    -So do the appropriate settings on swtich after you added voice vlan.
    -Create vlanXX interface if the voice stream will goto internet.
