XGS1210-12 V2: Compatible SFP10G-T Module
Tactice
Tactice Posts: 4
Hello Zyxel Team,
I am considering to purchase XGS1210-12 V2 and looking also for a compatible SFP10G-T Module. For example MikroTik S+RJ10.
But in one older discussion a user report that XGS1210-12 is not compatible with XGS1210-12. I am wondering if this has been improved in V2 version?
Alternatively, a list of compatible SFP10G-T module would be apperciated.
Here a non-china manufacturer is preferred.
Thank you.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Zyxel Employee
    Hi there,
    In case you still want to use the SFP10G-T, please refer to Zyxel SFP10G-T.
    Please note that SFP10G-T modules tend to generate more heat. Ensure you have a suitable method to maintain your switch at a normal temperature for proper operation.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @Tactice ,
    SFP10G-T modules tend to generate more heat due to high power consumption, and the XGS1210-12 V2 has a fanless design. Therefore, we do not recommend using the SFP10G-T with the XGS1210-12 V2.
    For SFP10G usage, please refer to the recommendations below.
    Detailed information can be found in the datasheet.
    Zyxel_Judy
    Untitled Image
  • Tactice
    Tactice Posts: 4
    Hello Judy,
    thank you for the answer.
    My target connection is a NAS with SFP10G-T interface. There it is no possible to use glas fiber or other interface. But the usage of the switch is in a low load and cooler inviroment.
    Which is the right SFP10G-T to use on with the XGS1210-12 V2?
    Greetings
    Toni
  • Zyxel_Judy
    Hi there,
    Zyxel_Judy
    Untitled Image
  • Tactice
    Tactice Posts: 4
    Thank you.
  • Aaron_ML
    Aaron_ML Posts: 9 image  Freshman Member
    First Answer First Comment Friend Collector First Anniversary
    Using cooling fins is one method I used to cool down the switch. It may be helpful for you guys.
