Unable to reach port
T_G
T_G Posts: 17 image  Freshman Member
Hello
i have fowarded 3 ports on 3 internal ip (PC) , i have already created also the policy from wan to lan1 to manual ip.
For 2 are ok but one give me a error
It was a similar streaming from outside to inside, if i see the log i see this
Time
Category
Message
Src. IP
Src. Port
Dst. IP
Dst. Port
Note
Action
2024-06-11 19:27:17
Security Policy Control
Rule name:Sputnik, from WAN to LAN, TCP, service others, DNAT Packet, ACCEPT
xxx.xxx.x.xx
53203
192.168.0.146
5111
ACCESS FORWARD
Accept
Whats's wrong? Thanks
    PeterUK Posts: 4,446 image  Guru Member
    What your forwarding to might not be TCP?
    log show its forwarded what saying its its not?
  • T_G
    Hello, because the streaming not arrive to server.
    This is i make:
    Create a services with ports and add to group
    Then add the nat ( i try virtual server and 1:1 NAT)
    And the policy
    The log
    I try all that i know. Some help?
    The Device is USG FLEX 100H
