How to schedule a daily Access Point reboot
Skylink
Skylink Posts: 32
First Comment Friend Collector Seventh Anniversary
image  Freshman Member
edited April 2021 in Security
Hi!
I have already found and tested with success the script used to reboot USG60W manually.
But...in our office we often have to test the products of our customers and sometimes (somebody) can generate an IP conflict that "freeze" an access point.
My question:
is it possible to use a script to schedule a reboot (for a specific access point) every XX hours?
Otherwise there is a "supervision function" i can enable that can do this automatically?
  • Skylink
    Skylink Posts: 32
    Thank you.
    It works and is exactly what i was looking for.
    By the way, the CLI command is the only way to run the scheduling, right?
    I'm asking because I always prefer to have all the settings "under control" and, since I use the Web interface at 99.99%, this element would not be evident in the firewall.
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034
    image  Zyxel Employee
    @Skylink
    The firmware 4.35 version has a new feature “Web Console” can fulfill the request.
    User can use web interface to complete all CLI settings.
    Charlie
