USG110: P12 Certificate "errno:-17011"
bavaria
bavaria Posts: 30  Freshman Member
I try to import a new P12 certificates, which works for years.
Now the "import" under "certificates" gets error 'error -17011'.
"errmsg: PKI certificate type is not supported".
I can validate my p12 file with openssl, so the file is fine.
  • bavaria
    Hi
    It works now, I generate a new P12 certificate with LibreSSL 2.8.3 on Mac OSX,
    import does not work with
    OpenSSL 3.0.11 19 Sep 2023 (Library: OpenSSL 3.0.11 19 Sep 2023) Debian 12.
  • bavaria
  • bavaria
    Hi
