Flex 200 - Two factor authentication
Wanting to use this for l2tp users, to get an 2fa email for access to the network.
Spent an hour, no luck.
Wondering if it works?
Yes could not get Google Authenticator to work for VPN
Peter,
Not sure I understand. I'm not using google authenticator.
I tried this instruction sample. Are there any corrections or newer examples.
Is there a know working solution to use email link to allow access to l2tp vpn?
I have some other devices I can try, but I have several of these Flex 200's, be nice if it worked.
Bret
It will need to be added for Flex H models
Unless your talking about non H models in which case I got Email working on them
It's an old Flex 200/USG60 (not H Series)…Looks like I posted this in the wrong forum.
So you were able to get an l2tp ipsec vpn working with an email authorization link?
I will try once more
I tested SSL VPN and it work so l2tp ipsec vpn should not be a problem
When you set up the the Mail from keep it the same as user name Email you try with just TLS enabled or STARTTLS.
Some Email providers don't forward unknown Mail from or if you have a DDNS you need to add a spf Record like.
v=spf1 include:_spf.virginmedia.com ~all
also check SPAM
- 441 Beta Program
- 293 Service & License
