How do I change standby firmware boot-option
bbp
bbp Posts: 70
First Answer First Comment Friend Collector Seventh Anniversary
image  Ally Member
USG Flex 200H - Firmware 1.20(ABWV.2)
1.) How do I change standby firmware boot-option from 0 to 1?
boot-option - Show boot-option, which is used to reboot machine when
backup firmware upgrade successfully. 0:reboot, 1:not
reboot.
There's nothing in CLI Reference Guide for 1.20 firmware on how to change boot-option.
2.) How do I boot into standby firmware?
Also nothing in CLI Reference Guide for 1.20 firmware on how to boot into standby firmware.
    PeterUK Posts: 4,745
    image  Guru Member
    edited June 2024 Answer ✓
    its
    cmd firmware boot-number 1
    cmd firmware boot-number 2
    image  Guru Member
    its
  • bbp
    bbp Posts: 70
    image  Ally Member
    Thank you Peter. That works.
    Answer to my question number one is similar: cmd firmware boot-option 1
