Authorize Link URL Address not working at all or correctly
USG FLEX 200H V1.20(ABWV.2)
A whole load of problems
Authorize Link URL Address by from interface LAN PC1 with SSL VPN on PC2 does not display the URL on PC1 by policy control rule to allow unless all policy control is disabled!
Authorize Link URL Address by from interface missing WAN interfaces
Authorize Link URL Address by user defined like zyxel-router7.ddns.net by HTTPS not using Server Certificate for zyxel-router7.ddns.net and uses default.
Even with policy control disabled for the Authorize Link URL Address for Google Authenticator code to enter in does not work only when setting up Google Authenticator for a user it says vailed but using it with the Authorize Link URL Address shows with Authentication Fail(invalid code)
Hi @PeterUK,
Did this issue occur after updating the firmware from V1.20.C0 to V1.20p2?
I only started testing this on V1.20p2
V1.21(ABWV.0)ITS-24WK35-0813-240800592
So I'm I the only one seeing this issue?
USG FLEX 200H V1.30(ABWV.1)
Ok for real this does not work at all!
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
