Dual networks - where WAN2 is simply the LAN of the other network - cant talk
JPElectron
JPElectron Posts: 8
edited June 2024 in Security
Two companies in the same office both have their own networks, and their own (different) ISPs. Neither company is paying for static IPs from the ISPs, so they each only get only 1 dynamic IP. Thus, to have a backup Internet connection, I connected WAN2 of each company's firewall to the LAN of the other. These companies also agree to share printers on each-others networks.
ISP fail-over works great…
Side A can access the printers in Side B's network without issue…
However Side B cannot access anything in Side A's network (the only connection is WAN2 of the USG is connected to the LAN of the opposite company)
I have made no special rules for this, side A to B just works.
However side B to A does not work in the same way, as I would have expected.
How can I solve this?
    PeterUK Posts: 3,892  Guru Member
    I found a problem with LAN2 on my FLEX200 not sure if that could cause a problem maybe try reserved and not LAN2
    maybe you added a routing rule or miss a Policy Control?
    I think their is another way to do this I have a think….
    edited June 2024
    here is the other way
    On side A
    Make zone WAN2 move WAN2 to zone WAN2
    WAN2 IP 10.255.255.1/24 gateway 10.255.255.2
    routing rule
    incoming LAN of 192.168.22.0/24
    destination 10.0.0.0/24
    next hop gateway 10.255.255.2
    SNAT none
    Policy Control
    LAN zone of 192.168.22.0/24 to WAN2
    WAN2 to LAN zone of 192.168.22.0/24
    On side B
    WAN2 IP 10.255.255.2/24 gateway 10.255.255.1
    routing rule
    incoming LAN of 10.0.0.0/24
    destination 192.168.22.0/24
    next hop gateway 10.255.255.1
    SNAT none
    Policy Control
    LAN zone of 10.0.0.0/24 to WAN2
    WAN2 to LAN zone of 10.0.0.0/24
    connect side A WAN2 and side B WAN2
  • I appreciate the help - in troubleshooting this I determined the switch port that goes over to the other office WAN2 port was tagged the wrong VLAN, meaning effectively that WAN2 on the B side was not connected, hence the real reason for this problem. Everything works correctly now.
    Good that your way works but you might find that if you go from 192.168.22.22 to 10.0.0.11 that what 10.0.0.11 see is from 10.0.0.2
  • Yes, you are correct, the traffic from the other LAN all appears as from the single IP assigned to the WAN2 interface - in my case I'm OK with that.
    You might be able to do a routing rule to stop that along with a static route but if you happen with what you got go with it.
  • jkocovski
    jkocovski Posts: 5  Freshman Member
    @PeterUK i have the same issue now. just with different firewalls. i wrote down everything but as it is the first posting i have to wait for it to be approved first. I have one zywall 110 and one usg flex 200.
    i tried to follow your setup idea but failed on the first sentence. I could add a zone wan2 but i`m unable to delete wan2 from wan. Cannot remove default member it said. Am i`m doing something wrong?
    On the old Zywall 110 the WAN zone have both WAN1 and WAN2 to it that you can't remove one or the other on the FLEX200 you can
  • jkocovski
    @PeterUK ok, i understand. But how then to proceed with your setup then?
    you can use the OPT port
