WAC6502D-E
rmacuda
rmacuda Posts: 6
Foud this and want to reuse in home. Please suggest where to find firmware 5,50
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,204  Zyxel Employee
    edited June 2024
    Hi @rmacuda ,
    If you have no specific concerns about using version 5.50, we recommend upgrading to 6.28 the latest firmware for the WAC6502D-E.
    If you have any concerns or questions, please let us know.
  • rmacuda
    rmacuda Posts: 6
    Hi Judy,
    I've no concerns about 5.50, the only problem is that on the link https://webservice.zyxel.com/end-of-life there is no firmware to download and pararelly link to sharepoint provided by you also does not work for me
    Regards,
    Roman
  • Zyxel_Judy
    Hi Roman,
    Thank you for your feedback. Please try the link we provided above; we have already made adjustments to it.
    Regarding the EOL link, we will check and upload the latest firmware for the WAC6502D-E.
  • rmacuda
    rmacuda Posts: 6
    Hi Judy.
    Link still does not work for me:
    1. I have an output in polish so not usefull for you but in general meaning is: IT does not work
    2. Problem type: my email does not exists in catalog
    Regards
  • Zyxel_Judy
    Hi @rmacuda ,
    Please help to try this link or the link we provided above. Thank you!
  • rmacuda
    rmacuda Posts: 6
    Thanks .. this link works.
    Appreciate your help.. great thank you
    Regadrs
    Roman
