Been seeing this error
Hi @PeterUK,
We will have fix in next FCS. 1.30.
Thank your feedback.
Kevin
@Rudolph Colon
Here's how you can generally achieve this on a network device, such as a Cisco router or switch:- Checking Firmware Version:You can use the following command to check the firmware version on a Cisco device:
Comparing Running and Startup Configurations:To compare the running configuration with the startup configuration, use:
Then you can use the
diff
command to compare the two if you have access to a Unix-like shell. Alternatively, on Cisco devices, you can directly use:
However, for a more detailed and precise response, please specify the type of device you're working with, as the commands can vary between different manufacturers and models.0
- 414 Beta Program
- 2.3K Nebula
- 132 Nebula Ideas
- 92 Nebula Status and Incidents
- 5.4K Security
- 182 USG FLEX H Series
- 258 Security Ideas
- 1.4K Switch
- 71 Switch Ideas
- 1K Wireless
- 37 Wireless Ideas
- 6.2K Consumer Product
- 237 Service & License
- 374 News and Release
- 79 Security Advisories
- 24 Education Center
- 2.9K FAQ
- 80 About Community
- 69 Security Highlight
