VPN stopped working
update
So from the time 22th 23:50 it stopped working going in a loop of trying to connect to the 23th 02:57 its now connected.... log show a lot of "[COOKIE] Invalid cookie, no sa found"
4 days uptime this happened again there is this problem then there is the other problem the two are not the same where the bridge on VPN300 passes UDP 4500 but VPN tunnel drops it will try and try and likely should connect in some hours on the same IP but still a problem why it not connecting when it should
from FLEX200
VPN300
V5.37(ABFC.2)
Still happing VPN stopped working this is not the same as this
^ which I think by me removing the LAG and just having a simple two port bridge has solved that
VPN just goes in a loop
2024-06-28 17:21:18
info
IKE
[COOKIE] Invalid cookie, no sa found [count=2]
10.187.154.135:500blank:4500
IKE_LOG
2
2024-06-28 17:21:18
info
IKE
The cookie pair is : 0x7b576d8c225d393a / 0x2f09f7269c493b97 [count=2]
IKE_LOG
18
2024-06-28 17:21:03
info
IKE
Send:[KE][NONCE][PRV][PRV]
10.187.154.135:500blank:500
IKE_LOG
19
2024-06-28 17:21:03
info
IKE
IKE_LOG
22
2024-06-28 17:21:03
info
IKE
Send:[SA][VID][VID][VID][VID][VID][VID][VID][VID][VID][VID]
IKE_LOG
23
2024-06-28 17:21:03
info
IKE
Send Main Mode request to [blank]
IKE_LOG
24
2024-06-28 17:21:03
info
IKE
Tunnel [link_to_flex200_4G] Sending IKE request
IKE_LOG
25
2024-06-28 17:21:03
info
IKE
The cookie pair is : 0x7b576d8c225d393a / 0x0000000000000000 [count=3]
IKE_LOG
27
2024-06-28 17:20:47
info
IKE
IKE_LOG
28
2024-06-28 17:20:47
info
IKE
The cookie pair is : 0xca94966c8872f095 / 0xd2190f5a85b316cf [count=2]
IKE_LOG
42
2024-06-28 17:20:29
info
IKE
IKE_LOG
43
2024-06-28 17:20:29
info
IKE
IKE_LOG
46
2024-06-28 17:20:29
info
IKE
IKE_LOG
47
2024-06-28 17:20:29
info
IKE
IKE_LOG
48
2024-06-28 17:20:29
info
IKE
IKE_LOG
49
2024-06-28 17:20:29
info
IKE
The cookie pair is : 0xca94966c8872f095 / 0x0000000000000000 [count=3]
IKE_LOG
58
2024-06-28 17:20:16
info
IKE
IKE_LOG
59
2024-06-28 17:20:16
info
IKE
The cookie pair is : 0x4cbdfa8a11ca935b / 0x3106c9629516c8ad [count=2]
IKE_LOG
71
2024-06-28 17:19:59
info
IKE
IKE_LOG
72
2024-06-28 17:19:59
info
IKE
IKE_LOG
75
2024-06-28 17:19:59
info
IKE
IKE_LOG
76
2024-06-28 17:19:59
info
IKE
IKE_LOG
77
2024-06-28 17:19:59
info
IKE
IKE_LOG
78
2024-06-28 17:19:59
info
IKE
The cookie pair is : 0x4cbdfa8a11ca935b / 0x0000000000000000 [count=3]
IKE_LOG
79
2024-06-28 17:19:41
info
IKE
IKE_LOG
80
2024-06-28 17:19:41
info
IKE
The cookie pair is : 0x6ea742077a3a1deb / 0xd7af22105c5b5bbd [count=2]
IKE_LOG
93
2024-06-28 17:19:26
info
IKE
IKE_LOG
94
2024-06-28 17:19:26
info
IKE
IKE_LOG
97
2024-06-28 17:19:25
info
IKE
IKE_LOG
98
2024-06-28 17:19:25
info
IKE
IKE_LOG
99
2024-06-28 17:19:25
info
IKE
IKE_LOG
100
2024-06-28 17:19:25
info
IKE
The cookie pair is : 0x6ea742077a3a1deb / 0x0000000000000000 [count=3]
IKE_LOG
104
2024-06-28 17:19:10
info
IKE
IKE_LOG
105
2024-06-28 17:19:10
info
IKE
The cookie pair is : 0x951287bb6803c07d / 0xb5a9e3d0de57aff6 [count=2]
IKE_LOG
117
2024-06-28 17:18:55
info
IKE
IKE_LOG
118
2024-06-28 17:18:55
info
IKE
IKE_LOG
121
2024-06-28 17:18:55
info
IKE
IKE_LOG
122
2024-06-28 17:18:55
info
IKE
IKE_LOG
123
2024-06-28 17:18:55
info
IKE
IKE_LOG
124
2024-06-28 17:18:55
info
IKE
The cookie pair is : 0x951287bb6803c07d / 0x0000000000000000 [count=3]
IKE_LOG
126
2024-06-28 17:18:35
info
IKE
IKE_LOG
127
2024-06-28 17:18:35
info
IKE
The cookie pair is : 0x6aa249cddb51cb9d / 0x0170db1383dda361 [count=2]
IKE_LOG
149
2024-06-28 17:18:21
info
IKE
IKE_LOG
150
2024-06-28 17:18:21
info
IKE
IKE_LOG
153
2024-06-28 17:18:21
info
IKE
IKE_LOG
154
2024-06-28 17:18:21
info
IKE
IKE_LOG
155
2024-06-28 17:18:21
info
IKE
IKE_LOG
156
2024-06-28 17:18:21
info
IKE
The cookie pair is : 0x6aa249cddb51cb9d / 0x0000000000000000 [count=3]
IKE_LOG
160
2024-06-28 17:18:08
info
IKE
IKE_LOG
161
2024-06-28 17:18:08
info
IKE
The cookie pair is : 0xfcbffb47f7681327 / 0x6195c47eee0d1d9b [count=2]
IKE_LOG
and after leaving it in a loop of trying to connect it did
from when it stopping working
Arrival Time: Jun 28, 2024 15:59:31.745253000 GMT Summer Time
to working
Arrival Time: Jun 28, 2024 22:47:09.830605000 GMT Summer Time
VPN dropped out again at the same my internet dropped and the VPN is trying to reconnect but is failing going to leave it and see if it reconnects at some point.
2024-09-04 10:42:20
info
IKE
Phase 1 IKE SA process done
10.71.71.221:4500
92.239.xxx.xxx:4500
IKE_LOG
2
2024-09-04 10:42:20
info
IKE
Recv:[ID][HASH]
92.239.xxx.xxx:4500
10.71.71.221:4500
IKE_LOG
3
2024-09-04 10:42:20
info
IKE
The cookie pair is : 0x21501875e72460a2 / 0x21dfe45a2618b9dd
92.239.xxx.xxx:4500
10.71.71.221:4500
IKE_LOG
4
2024-09-04 10:42:20
info
IKE
Send:[ID][HASH]
10.71.71.221:4500
92.239.xxx.xxx:4500
IKE_LOG
5
2024-09-04 10:42:20
info
IKE
The cookie pair is : 0x21dfe45a2618b9dd / 0x21501875e72460a2 [count=2]
10.71.71.221:4500
92.239.xxx.xxx:4500
IKE_LOG
6
2024-09-04 10:42:20
info
IKE
Recv:[KE][NONCE][PRV][PRV]
92.239.xxx.xxx:500
10.71.71.221:500
IKE_LOG
7
2024-09-04 10:42:19
info
IKE
10.71.71.221:500
92.239.xxx.xxx:500
IKE_LOG
8
2024-09-04 10:42:19
info
IKE
10.71.71.221:500
92.239.xxx.xxx:500
IKE_LOG
9
2024-09-04 10:42:19
info
IKE
Recv:[SA][VID][VID][VID][VID][VID][VID][VID][VID][VID][VID]
92.239.xxx.xxx:500
10.71.71.221:500
IKE_LOG
10
2024-09-04 10:42:19
info
IKE
The cookie pair is : 0x21501875e72460a2 / 0x21dfe45a2618b9dd [count=2]
92.239.xxx.xxx:500
10.71.71.221:500
IKE_LOG
11
2024-09-04 10:42:19
info
IKE
10.71.71.221:500
92.239.xxx.xxx:500
IKE_LOG
12
2024-09-04 10:42:19
info
IKE
Send Main Mode request to [92.239.xxx.xxx]
10.71.71.221:500
92.239.xxx.xxx:500
IKE_LOG
13
2024-09-04 10:42:19
info
IKE
10.71.71.221:500
92.239.xxx.xxx:500
IKE_LOG
14
2024-09-04 10:42:19
info
IKE
The cookie pair is : 0x21dfe45a2618b9dd / 0x0000000000000000 [count=3]
10.71.71.221:500
92.239.xxx.xxx:500
IKE_LOG
15
2024-09-04 10:42:07
info
IKE
10.71.71.221:500
92.239.xxx.xxx:4500
IKE_LOG
16
2024-09-04 10:42:07
info
IKE
The cookie pair is : 0x4e5abc8b83a87341 / 0xceebc8e6453cc697 [count=2]
10.71.71.221:500
92.239.xxx.xxx:4500
IKE_LOG
17
2024-09-04 10:42:07
info
IKE
ISAKMP SA [link_to_flex200_4G] is disconnected
10.71.71.221:4500
92.239.xxx.xxx:4500
IKE_LOG
18
2024-09-04 10:42:07
info
IKE
10.71.71.221:4500
92.239.xxx.xxx:4500
IKE_LOG
19
2024-09-04 10:42:07
info
IKE
Received delete notification
92.239.xxx.xxx:4500
10.71.71.221:4500
IKE_LOG
20
2024-09-04 10:42:07
info
IKE
Recv:[HASH][DEL]
92.239.xxx.xxx:4500
10.71.71.221:4500
IKE_LOG
21
2024-09-04 10:42:07
info
IKE
The cookie pair is : 0xceebc8e6453cc697 / 0x4e5abc8b83a87341 [count=2]
92.239.xxx.xxx:4500
10.71.71.221:4500
IKE_LOG
24
2024-09-04 10:41:50
info
IKE
10.71.71.221:4500
92.239.xxx.xxx:4500
IKE_LOG
25
2024-09-04 10:41:50
info
IKE
Recv:[ID][HASH]
92.239.xxx.xxx:4500
10.71.71.221:4500
IKE_LOG
26
2024-09-04 10:41:50
info
IKE
92.239.xxx.xxx:4500
10.71.71.221:4500
IKE_LOG
27
2024-09-04 10:41:50
info
IKE
Send:[ID][HASH]
10.71.71.221:4500
92.239.xxx.xxx:4500
IKE_LOG
28
2024-09-04 10:41:50
info
IKE
10.71.71.221:4500
92.239.xxx.xxx:4500
IKE_LOG
29
2024-09-04 10:41:50
info
IKE
92.239.xxx.xxx:500
10.71.71.221:500
IKE_LOG
30
2024-09-04 10:41:49
info
IKE
10.71.71.221:500
92.239.xxx.xxx:500
IKE_LOG
31
2024-09-04 10:41:49
info
IKE
10.71.71.221:500
92.239.xxx.xxx:500
IKE_LOG
32
2024-09-04 10:41:49
info
IKE
92.239.xxx.xxx:500
10.71.71.221:500
IKE_LOG
33
2024-09-04 10:41:49
info
IKE
92.239.xxx.xxx:500
10.71.71.221:500
IKE_LOG
34
2024-09-04 10:41:49
info
IKE
10.71.71.221:500
92.239.xxx.xxx:500
IKE_LOG
35
2024-09-04 10:41:49
info
IKE
10.71.71.221:500
92.239.xxx.xxx:500
IKE_LOG
36
2024-09-04 10:41:49
info
IKE
10.71.71.221:500
92.239.xxx.xxx:500
IKE_LOG
37
2024-09-04 10:41:49
info
IKE
The cookie pair is : 0x4e5abc8b83a87341 / 0x0000000000000000 [count=3]
10.71.71.221:500
92.239.xxx.xxx:500
IKE_LOGcould the problem be I use Site-to-site with Dynamic Peer on one end?
So 8:50am today was when I lost VPN working and 3:53pm was when after itself trying to reconnect now is up.
Seem like when my internet drops out between the two ends one side is not detecting the drop and on reconnecting fails a
slogs show Phase 1 IKE SA process done the problem could be Phase 2 holds on the last known encryption but the other end want to start over? so if I set Phase 2 SA life time low 180 then the next time this happens it will be that long to start the encryption over?0
- 433 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 115 Nebula Status and Incidents
- 6K Security
- 389 USG FLEX H Series
- 295 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
