XS1930 route traffic to wan
Hello community,
i have the following scenario: various vlans configured on the firewall and on the xs1930 (more ore less each port is a vlan, port 1 is the uplink to the firewall). Now i configured the xs1930 with each ip address for any vlan since i want it to be the gateway of all the vlans (this to use the 10gb/s speed for inter vlan traffic from edge switches to core switch). I configured the classifier and policy rules so that some vlans can see some other vlans.
In the end i configured some firewall rules to let the vlans see the zywall and allow traffic to the WANs.
So far so good
Now i had the problem to let the client inside the vlan surf the web: my solution was to enter in
system / ip setup / ip setup / default gateway
one of the firewall ip addresses (i used the one of vlan20). After this i am able to access internet from all the clients which are inside a vlan which is allowed to see the vlan20. Unfortunately i don't have a vlan which can be seen by ALL the other vlans but obviously i need all the vlan to get to the internet.
Is there any way to tell something like a "next hop" in the switch so that if the required IP is not inside of any vlan he will route to an ip address according to the source. (just to be verbose i mean for example: if i am 192.168.20.108 and i ask for 8.8.8.8 than the switch has to route this request to 192.168.20.1 while if i am 192.168.30.150 and i ask for 8.8.8.8 it should route it to 192.168.30.1)?
Please consider that i bought the extra Access L3 license!
PS i know that i can easily let the firewall make all the job but my firewall has no 10gb ports and i don't want that the request from vlan_office to vlan_server will be narrowed to 1gbps when i have a switch-switch connection of 10gbps.
PS2 configuration on-premise
Thank you
Not yet got a Zyxel switch for doing L2+/L3 routing but have done it on my netgear M4100-D12G
In my case I have the Zyxel Flex 200 with VLAN 6 untag to port 1 of of netgear
so it be 192.168.255.237 on FLEX 192.168.255.200 on switch Untag port 1 PVID 6
VLAN 138 PVID 138 on port 11 untag IP 192.168.138.13
client can not get IP from FLEX so is set to static on port 11 192.168.138.6 gateway 192.168.138.13
you then may need a rule on switch for 0.0.0.0/0 to gateway 192.168.255.237 with high Metric
on the FLEX 200 do static route 192.168.138.0/28 Gateway 192.168.255.200 to switch
Then it should work for internet traffic
Hi @QuiteSmart
To better understand your current setup, could you please collect the startup-config.conf file from your ZyWALL and the tech support file from your XS1930 switch, and send them to us through a private message?
Kay
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
