Is there any chance to convert config from zyxell zywall usg 300 to usg 310
Michal_Pan
I have a problem with converting the configuration file from zywall usg 300 to usg 310. When I try to convert the config using https://convert.cloud.zyxel.com/ I get a message saying fail. Is there any way to import an old configuration file into a new device.
@Michal_Pan
As I checked it locally, the configuration can be converted from USG300 to USG310.
Can you private message your configuration for check further?
Charlie0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
