Zywall USG 20 fan operating logic
Cesare2
Cesare2 Posts: 2
edited June 2024 in USG FLEX H Series
Hi, I'm from Italy, excuse for my English…I have found 2 old Zywall USG20 (firmware update to last release) that everyone has the fan which start ad stop in loop every time.
It's a normal operation?
Thanks you for the attention and best regards.
Cesare
  • Wojtek
    Wojtek Posts: 18 image  Freshman Member
    First Answer First Comment Sixth Anniversary
    When the temperature of the device exceeds the limit temperature, the fans will turn on.
    When the fans cool the device below the limit temperature - they will turn off.
    In my USG210 it is like this: https://community.zyxel.com/en/discussion/1181/usg210-temperature
    Regards
    Wojtek
  • Wojtek
    Regards
    Wojtek
  • Cesare2
    Cesare2 Posts: 2
    edited June 2024
    Thank you for the answer.
    My firewall is EOS, therefore isn't safe?
    Cesare
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    @Cesare2 You can check the hardware temperature by debug hardware fan-get
    The safe value should be under 70°C
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    Current days are "normally hot" in italy. USG20 is a really old device, therefore maybe the thermal media between heatshink and cpu is closer to destroyed than in service.
    Consider a thermal media replacement, if you know how to do it.
