Unable to automatically reconnect to the 6GHz SSID
2»
  • TLG
    TLG Posts: 24 image  Freshman Member
    First Comment Sixth Anniversary
    edited May 2024
    For anybody else having similar issues, I was able to fix this by changing 6GHz channel selection from auto to manual and then trying different channels and then turning off wifi and then turning it back on until I found channels that seemed to work better with my phone and other devices.
    EDIT: I thought it was working, but same effect. Initially connects to 6GHz, but then after leaving and coming back it never reconnects.
  • otiscavin
    otiscavin Posts: 2
    edited July 2024
    • Ensure your device supports Wi-Fi 6E. Older devices typically only support 2.4GHz and 5GHz bands. Check your device specifications or settings to confirm it supports the 6GHz band.
  • TLG
    Thanks, my device does support 6GHz band, and it will connect briefly at times.
