VPN Ip Sec
Antonio967
Antonio967 Posts: 11  Freshman Member
Hello everyone, I have configured Vpn IpSec Client To Site on a USG FLEX 200, open tunnel but the only resource I reach is the firewall on the correct remote subnet, any other device on the remote subnet is not reachable...
Can you tell me where the problem is?
Thank you
Antonio
    PeterUK Posts: 3,892  Guru Member
    what is your local and remote policy and LAN subnets of each end?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,529  Zyxel Employee
    edited July 2024 Answer ✓
    Hi @Antonio967,
    May I know did you create the remote IPSEC VPN via wizard?
    If yes, please check the firewall rules of the other devices.
    In the handbook of USG FLEX, chapter 1 Remote access VPN Wizard-IKEv2 Client, we were able to access the server in USG FLEX's LAN.
    https://download.zyxel.com/USG_FLEX_700/handbook/USG%20FLEX%20700_ZLD5.31_Handbook.pdf
    If not, please check the local and remote policy and LAN subnets of each end, or create the remote IPSEC VPN via wizard.
    Zyxel Melen
