Unable to Establish VPN Connection
What port forwarding configuration should I set up?
your want UDP 500 and 4500
or just DMZ to FLEX
I will try right now, thanks for all
Kay, where can I download the .bat file from, other than the wizard mode?
Hi @Brandix
The .bat file can only be downloaded when you complete the setup using the wizard. Once you exit the wizard mode, there is no other place to download the .bat file.
Currently, if you need to download the .bat file again, you will need to go through the wizard again.
Kay
- 602 USG FLEX H Series
- 480 News and Release
