[Release Note] NWA130BE - V6.75 Patch 0 firmware has been released
Zyxel_Melen
Zyxel_Melen Posts: 2,654  Zyxel Employee
edited July 2024 in WirelessLAN New Release
Zyxel Access Points Firmware Release Note
April 2024
Overview
This document provides firmware release information on Zyxel Access Points platforms, introduce new Access Points, new features and enhancements, bug fix, known issues and workarounds information for Release V6.75 Patch0 C0.
Supported Platforms
(Click Hyperlink to download the firmware directly)
Zyxel NWA130BE - V6.75(ACIL.0)C0
New Features and Enhancements
N/A
Bug Fix
N/A
Known Issue
C=Cloud mode, M=Managed, S=Standalone mode
Known Issue
1. [eITS:240400399] [Symptom] In Mesh network, client connected to repeater AP, the Rate Limit feature upload rate not works.
Zyxel Melen
«1
  • Chris888
    Chris888 Posts: 43  Freshman Member
    First Comment Friend Collector Community MVP
    edited April 2024
    Thanks, but what is the different to 6.70?
  • Chris888
  • Chris888
    When will MLO arrive in the firmware? As a Standard-Feature of Wifi 7 i hope it will arive early….
  • Zyxel_Melen
  • Chris888
    Hi, any news to MLO?
  • Zyxel_Kay
    Zyxel_Kay Posts: 1,262  Zyxel Employee
    Hi @Chris888
    The MLO technology is a default feature equipped on the WiFi 7 access point. For more detailed specifications about the WiFi 7 AP NWA130BE, please refer to its datasheet: NWA130BE_2.pdf (zyxel.com)
    Kay
  • Chris888
    Hi Kay,
    some words of your colleguas: Nebula Ticket #240301568
    Dear Christian,Thank you for your reply.Regarding the inquiry you mentioned, it has been confirmed that the NWE130BE currently does not support MLO, but this is expected to be supported in future firmware versions. Additionally, it appears that your issue has been resolved, and we expect to close the ticket in this system. If you have any other questions, please feel free to contact us.Thank you.Best regards,Jami
    So, any news reagrding MLO?
  • Zyxel_Kay
    Hi @Chris888
    Yes, the MLO feature is supported in the device hardware. However, since WiFi 7 clients are not very common at this stage, this function is currently not enabled. To ensure this feature is stable and performs well, we plan to conduct more rigorous testing on the device before unlocking this feature in the software. We aim to enable this feature in a future firmware release, which is expected in Q3 2024.
    Stay tuned to our https://community.zyxel.com/en/categories/wlan-news-and-release for the latest updates.
    Kay
  • Chris888
    Hi Kay,
    thanks a lot! Looking forward to Q3.
    Regards
    Christian
  • Chris888
    Hi, any news? Regards, Christian
