SSL VPN issues
brainfarm
brainfarm Posts: 1 image  Freshman Member
Second Anniversary
with USG FLEX 50 (USG20-VPN) and FW V5.38(ABAQ.0) / 2024-03-28 01:18:17 when i try to connect i got:
[ 2024/07/10 08:28:10 ][SecuExtender Helper] Request(104): REMOVE 526647306/1650147421 49 4294967295 4294967295
[ 2024/07/10 08:28:10 ][SecuExtender Helper] Remove Routing
[ 2024/07/10 08:28:10 ][SecuExtender Helper] Remove prioritize routing
[ 2024/07/10 08:28:10 ][SecuExtender Helper] Get netsh path = powershell
[ 2024/07/10 08:28:10 ][SecuExtender Helper] ia is null
[ 2024/07/10 08:28:10 ][SecuExtender Helper] Failed to read from client(2): 109, 0
[ 2024/07/10 08:28:10 ][SecuExtender Helper] Start to Disconnect pipe...
[ 2024/07/10 08:28:10 ][SecuExtender Helper] Shutting down a pipe connection instance...
Here attached my configuration
Client is Secure Extender
4.0.5.0
Thank you
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,580 image  Zyxel Employee
    Hi @brainfarm,
    Could you also share the settings on SecuExtender? And is your USG FLEX 50 behind NAT?
    Zyxel Melen
