[2023 November Security Monthly Express] Elevating Remote Access with SecuExtender SSL VPN Support
zyxel_Lin
zyxel_Lin Posts: 73  Zyxel Employee
Friend Collector Third Anniversary
edited November 2023 in Security Highlight
In the ever-evolving world of remote connectivity, VPNs have become an indispensable tool for businesses and individuals alike. In this article, we will delve into the significance of SSL VPN, explore why it is preferred over IPSec VPN, and provide a summary of the product highlights and compatibility of SecuExtender.
What is SSL VPN?
Secure Socket Layer Virtual Private Network (SSL VPN) is a secure and encrypted protocol that enables users to establish a secure connection between their devices and a private network over the internet. It uses SSL/TLS protocols to create a secure tunnel for transmitting data, ensuring confidentiality and integrity. SSL VPN provides a flexible and user-friendly approach to remote access, allowing users to connect from any location while maintaining stringent security measures.
Why do people prefer to use SSL VPN rather than IPSec VPN?
SSL VPN has gained popularity due to several compelling reasons:
  1. Ease of use: SSL VPNs operate through web browsers, which makes them more accessible to a wide range of users.
  2. Firewall compatibility: IP Sec VPN is supported across different vendors and platforms, making it compatible with a broad range of devices. However, configuration and interoperability can sometimes be complex, especially when dealing with different vendors and network environments.SSL VPNs are typically implemented using a web browser or a client software application, and they provide remote access to specific applications or resources. While SSL VPNs can work with firewalls from the same vendor, they are not limited to such configurations.
  3. Easy to traverse the network perimeters: Most Wi-Fi routers and other network equipment contain NAT firewalls. So they reject unrecognized Internet traffic and data packets without port numbers to protect against threats. IPSec VPN traffic using ESP or encapsulate ESP packets into UDP packets(usually UDP 4500) which could be block by network router/firewall. SSL VPN can using TCP port 443 like HTTPS are better suited for bypassing NAT firewalls. Since almost all networks allow HTTPS traffic through port 443. This makes SSL more helpful in bypassing firewalls and other forms of censorship that block port-based traffic.
  4. Portability: SSL VPN can be used on various devices, including laptops, smartphones, and tablets, providing users with flexibility and convenience.
SecuExtender SSL VPN support
SecuExtender, a leading VPN client, now incorporates SSLVPN support into its subscription plans. This update brings the Top 5 advantages, including:
  • Robust Security: SecuExtender employs strong encryption algorithms to ensure the confidentiality and integrity of transmitted data, safeguarding sensitive information from unauthorized access.
  • Platform Compatibility: SecuExtender is compatible with major operating systems, including Windows, and macOS.
  • Seamless Integration: With SSLVPN support, SecuExtender seamlessly integrates with existing infrastructure, including firewalls and network configurations, allowing for hassle-free implementation.
  • User-Friendly Interface: SecuExtender boasts an intuitive and user-friendly interface, making it easy for both technical and non-technical users to configure and establish VPN connections.
  • Cost-Effective Subscription Plans: SecuExtender offers flexible and cost-effective subscription plans, catering to the needs of individuals and businesses of all sizes.
The addition of SSLVPN support to SecuExtender's subscription plans marks a significant milestone in providing users with enhanced security, flexibility, and ease of use. Whether you are a tech-savvy individual or a business seeking reliable and secure remote connectivity, SecuExtender with SSL VPN support is poised to deliver a seamless and robust solution.
  • TeleCrew
    TeleCrew Posts: 3  Freshman Member
    hallo,
    SSL VPN wir von Nebula NICHT unterstützt.. Warum dann diese "Werbe" Mail ?
  • OWB
    OWB Posts: 24  Freshman Member
    From a security perspective, isn't then IPSec VPN considered more secure than SSL VPN?
    Best regards Ole
  • Sulo
    Sulo Posts: 1
    From a security standpoint, would IPSec VPN be regarded as more secure compared to SSL VPN, especially considering the security requirements of online games?
    Warm regards,
    Sulo
  • Xhozief
    Xhozief Posts: 1
    "Introducing SecuExtender SSL VPN support is a significant step forward in enhancing remote access capabilities, providing a secure and reliable connection for users regardless of their location. This advancement ensures that accessing sensitive data and resources remotely is not only convenient but also prioritizes security, safeguarding against potential threats using Red Ball 4
  • Comet
    Comet Posts: 1
    Hello Sulo,
    From a security perspective, both IPSec and SSL VPNs have their strengths and can be highly secure when properly configured. IPSec VPNs are often considered more secure due to their robust encryption and authentication methods. However, SSL VPNs offer flexibility and ease of use, which can be crucial for online games with varying security requirements.
    Speaking of online games, have you ever tried playing Mahjong? It's a great way to relax and challenge your mind.
    Warm regards,
    Comet
  • Bevisflyn
    Bevisflyn Posts: 1
    edited July 12
    I like use SSL VPN over IPSec VPN
    Easier to use as it operates through web browsers.
    Better compatibility firewall as it can work with firewalls from different vendors.
    Can more easily traverse network perimeters and bypass firewalls/NAT by using standard HTTPS port 443.
    More portable as it can be used on various devices like laptops, smartphones, and tablets papa's scooperia
  • Makir
    Makir Posts: 1
    I prefer using SSL VPN over IPSec VPN for several reasons. Firstly, SSL VPN is easier to use since it operates through web browsers, eliminating the need for additional software installations. Its compatibility with firewalls from different vendors makes it more versatile. blob opera Additionally, SSL VPN can effortlessly traverse network perimeters and bypass firewalls or NAT by using the standard HTTPS port 443. This makes it more reliable in various network environments. Finally, SSL VPN is highly portable, allowing seamless use on a wide range of devices, including laptops, smartphones, and tablets.
