Remove an Static IP entry on a LAN interface gives error
If I try to remove an Static IP entry on a LAN interface I get:
CLI Number: 17
Error Number: -4005
Error Message: 'DHCP pool does not exist.'
Everything I try to do to resolve this, does not solve the problem. There are entries in de the tables that work!
Can you help?
Hi there,
I solved the issue by removing the trouble giving entry in de IP/<AC binding menu option. Gives also the option to remove an entry out of the Static IP Table and that remove there worked.
Thanks!
I reactivate this old thread. We tried to release an assigned IP address on our USG Flex 700 (v5.38). Therefore we went to
CONFIG > Network > Interface > Ethernet > Static DHCP Table
and tried to remove the corresponding MAC/IP entry from static DHCP table of the affected subnet. Unfortunately this was not possible and USG returned the o.m. errors.
To solve it, we still have to remove the IP/MAC entry in
CONFIG > Network > IP/MAC Binding > affected Subnet
first, although the affected subnet is not activated for IP/MAC Binding!
Is it a bug or a feature?
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 457 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
