Login GS2210-24HP
Hi @FamWeibel,
You need to find out the switch IP address before logging in. The default IP address is "192.168.1.1". You can also use ZON to find the GS2210's IP address if you cannot access it with the default IP address. You can find the default local credential on the back sticker.
Hope it helps.
Zyxel Melen0
Hi @FamWeibel,
Hope it helps.
Zyxel Melen0
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 460 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
