NWA130BE - "deauthenticated by key handshake fail" with certain devices
colonie
colonie Posts: 2
edited July 2024 in Wireless
For some strange reason only all of our Raspberry Pi Zero 2W can't connect due to the "deauthenticated by key handshake fail" error. Also log shows "left on […] Signal: -16dBm" which I've never seen even when the device (as in this case) sits in 1-2 meter range of the AP.
I tried the usual stuff changing channels, rate control, etc. Nothing worked so far. Every other Raspberry Pi is connecting - only the Zero 2W fails.
Does anybody know something I don't about this?
Thanks.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi @Fischje ,
    Since only the Pi Zero 2 W cannot connect to the NWA130BE's Wi-Fi, this suggests the issue is not with the NWA130BE itself. We recommend trying all the solutions we shared above, especially changing the SSID security to Open, which we found to be an effective solution for Pi Zero 2 W Wi-Fi connectivity issues based on discussions in other platform forums.
    We also recommend contacting Raspberry Pi support to determine whether this is a device-specific issue.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @colonie ,
    Due to the connection issues occurring only with the Zero 2W, we recommend the following steps:
    1. AP Firmware Update: Ensure your NWA130BE is running the latest firmware version 7.00P1
    2. Wi-Fi Driver Update (Raspberry Pi): The issue could be related to an outdated Wi-Fi driver on the Raspberry Pi Zero 2W. Try updating the Wi-Fi driver on your Raspberry Pi Zero 2W devices to the latest version available.
    3. Credentials: Carefully check your password when connecting the Zero 2W to the SSID.
    4. WPA2/WPA3 Compatibility: Double-check the security settings on your NWA130BE. Ensure that the configured WPA2/WPA3 settings are compatible with the Raspberry Pi Zero 2W. You can try temporarily switching to a different security protocol (e.g., open or WPA2 personal only) to see if it resolves the issue.
    If the problem persists, please collect the NWA130BE’s diagnostic file and provide us with the Zero 2W’s MAC address and the time of the connection attempt. We will check and inform you if we find anything.
    Zyxel_Judy
    Untitled Image
  • colonie
    colonie Posts: 2
    edited July 2024
    Hi @Zyxel_Judy ,
    thanks for the quick reply.
    1. Already did when setting it up.
    2. It's up to date.
    3. See 4.
    4. Tried "WPA2" and "none" - still the same handshake error.
    e4:5f:01:8f:dc:74 is the problematic devices.
    Here is the file.
  • Zyxel_Judy
    HI @colonie ,
    After reviewing the diagnostic file, there are no abnormal issues with the AP. Here are some steps you can try on the radio profile. The path: Configuration > Object > AP Profile > Radio > Edit
    1. Adjust the radio mode to 802.11b/g.
    2. Disable the A-MPDU and A-MSDU options in advanced settings.
    3. After applying the new settings to the AP, forget/delete the SSID (Wi-Fi) on the Pi Zero 2W’s Wi-Fi list and reconnect.
    If the issue persists, we recommend the following steps to further investigate the connection logs:
    1. Connect the Pi Zero 2W to the Wi-Fi multiple times.
    2. Immediately collect a new diagnostics file to ensure the related logs are retained.
    Additionally, you mentioned that other devices and Raspberry Pi models can connect to your Wi-Fi without issue using the same configuration. We have found many Wi-Fi connectivity issues with the Pi Zero 2W in the Raspberry Pi forum. Therefore, we also recommend reaching out to Raspberry Pi support to clarify if it is not an end-device issue.
    Zyxel_Judy
    Untitled Image
  • Chris888
    Chris888 Posts: 63 image  Ally Member
    First Comment Friend Collector First Anniversary Community MVP
    Try to disable MLO - if enabled.
  • Fischje
    Fischje Posts: 3 image  Freshman Member
    Hi there!
    Got a cups-server running on my pi zero 2 w. After swiching my APs to the NA130BE this is the only device that cant connect to my wifi. @colonie did you resolve this?
  • Fischje
    Hello??? Anybody, problem still exists!
  • Zyxel_Judy
    Hi @Fischje ,
    Zyxel_Judy
    Untitled Image
  • SteveA
    SteveA Posts: 1 image  Freshman Member
    Exact same problem here - a couple of my network music players absolutely refuse to connect to the NWA130BE no matter what setting I use. I believe this is a bug in the way the NWA130BE negotiates the handshake, or at least an obscure compound bug between the AP and certain clients that Zyxel will never get to the bottom of.
    My network music players connect to every AP I have tried, except the NWA130BE. I've now tried 9 different types of APs, all allow my music players to connect perfectly. That's strong evidence that the Zyxel AP is the issue.
