GS1915-8/8EP Unresponsive to Nebula and Zon and DHCP after some time
I have 2 switches there after some time ( hours or days ) after reboot stops to communicate with Nebula and ZON utility and DHCP and do not responses to ping
The only way to start communication again is to reboot them.
The cloud led is on while no communication with cloud
The switch network (ports) function of are working when there no communication with cloud
the 2 switches has firmware V4.80
OK
Are you using network monitor apps like Domotz or PRTG on your site?
Also, please enable Zyxel Support Access so we can investigate the issue more thoroughly.
Nami
No i am not using network monitor apps like Domotz or PRTG, it is a very small site
I have invited Zyxel support as administrator, should I open a new case?
There is no need to open a ticket; we can address and respond to your issue via this forum thread.
⇒ Please help us clarify the issue:
- Does this problem occur after rebooting, and does it return to normal when you reboot the switches again?
- When you mention rebooting, do you unplug the devices, or do you use the "reboot device" feature in Nebula?
Nami
Reboot means i Power off/Power On the switches, the "reboot device" feature in Nebula is not possible/active
Yes, after power on the switch it occur again after some time, The switches is brand new, only a week old.
We've noticed that you've already opened a support ticket, and our technical team has requested that you capture packet data when you're available.
We kindly ask that you continue to follow up and provide updates through that existing ticket. This will help ensure a more efficient and streamlined support process.
Thank you for your cooperation.
Nami
OK
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 320 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 399 News and Release
- 86 Security Advisories
- 3.8K FAQ
- 78 Security Highlight
