Firewall on prem - Login for some local users only from LAN
GiuseppeR
GiuseppeR Posts: 427  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
I have some on prem installations where I want to limit specific users to login to admin the webUI only if they are in LAN1.
I tried different Policy Rules but I can still login with those users when contacting the firewall via WAN.
How is it possible to have this working properly?
Thanks in advance
    PeterUK Posts: 3,887  Guru Member
    You can limit logon for a given LAN in system > WWW like this
    backup first
  • GiuseppeR
    Hello @PeterUK
    in that scenario I can logon only from LAN1.
    I need to logon also remotely via HTTPS page, I need to know if it is possible to have a group of users that could logon only from LAN1.
  • Zyxel_Kay
    Hi @GiuseppeR
    If you want to restrict the admin service to HTTPS only, go to CONFIGURATION > System > WWW and limit the HTTP service.
    With this configuration, logging in to the device GUI via HTTP will be denied.
    Kay
    edited July 2024
    you can limit by IP too if you try to login from any other IP you be denied
    or are you needing to limit to WAN or from VPN?
  • GiuseppeR
    Hello @Zyxel_Kay & @PeterUK
    thanks for the tips, but what I was looking for is something different.
    I desire to have a policy where I can force the ZyWALL to accept remote connections ONLY from some specific users.
    So I can have:
    • Admin1
    • Admin2
    • Admin3
    And ONLY Admin1 is able to connect via HTTPS to ZyWALL from WAN.
    Admin2 and Admin3 are inside a group "Local_Admin" and these Admin* are able to logon only if they are inside LAN.
    I tried to setup this limitation inside Security Policy but the firewall did not deny the access for that specific group "Local_Admin".
    Devices on a LAN not connected by VPN don't have a user name you can only use Security Policy user option if the client makes a connection by VPN to Zywall
  • GiuseppeR
    Hi @PeterUK
    I thought that when logging in via a user the ZyWALL checks the IP so it could understand easily from where that user is logging on
    edited July 2024
    Yes from IP but it does not know the user so you can have a Security Policy like
    from LAN1
    to zywall
    source 192.168.255.250
    service HTTPS
    note their is a default rule that might be enabled to allow all from LAN1 to zywall you need to disable
