AX7501 available in Spain?
Hello together,
I own a Zyxel AX7501 here in Switzerland because my ISP gave me this one. Now I want to buy the same router for my grandmother in Spain, but after a long search I can’t find the router in any online shop here in Spain. In Switzerland though it can be found anywhere.
Is there a reason for it? Would it cause problems if I were to connect the router here in Spain? My ISP has Auto-WAN so the IP get’s adressed automatically.
Thanks for the help!
Hello @Panda5598
You're welcome.
I have been looking and I am not sure, other than the AX7501-B0 has a CE marking so should be ok in Spain, but I don't know which ISPs will be happy with it.
In the following quick sales guide from Zyxel there is a telephone number for Zyxel Spain, so they might be able to help you. https://service-provider.zyxel.com/network-x-collateral/qsg_fiber_access_ont_emea_230831_a3.pdf
I don't want to suggest Amazon or eBay if it wastes your money.
Kind regards,
Tony
Hello @Panda5598
Welcome to the forum.
I think that it depends on which ISP your relative has in Spain.
AX7501 is approved on DIGI Spain according to the following
https://www.zyxel.com/service-provider//sites/default/files/2022-03/ZYX-Digi-Case-03-16-22_A4.pdf
Kind regards Tony
Thanks Tony,
Unfortunately I am not using the DIGI Spain ISP. Instead I use Citra, which in my region offers the best connectivity compared to the big companies. Will it cause any problems if I use it like this? And are there any places I would be able to buy this router from here in Spain?
Thanks!
Hello @Panda5598
You're welcome.
Kind regards,
Tony
- 243 Nebula Ideas
- 6.8K Security
- 783 USG FLEX H Series
- 390 Security Ideas
- 88 Switch Ideas
- 58 Wireless Ideas
- 7.3K Consumer Product
- 325 Service & License
- 528 News and Release
- 102 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
