USG20W : Firmware update ?
Spootzy
Spootzy Posts: 4  Freshman Member
Zyxel Certified Network Administrator - Security First Comment
Hello
May it' possible to apply a USG20W-VPN 5.38 firmware update to an USG20W ? (or where can i found the latest firmware for an USG20W).
Best regard's
S.
Best Answers
    PeterUK Posts: 3,993  Guru Member
    The USG20W is EOL you can download what I think is the newest firmware here
    Zywall/USG Series - v3.30P9 (WK48) firmware released! — Zyxel Community
  • Spootzy
    Thank you for this information.
    So as the latest firmware is 10 years old :
    1) Can this FW be used to establish a secure site-to-site IPSec VPN tunnel (with USG60) ?
    2) Is it always secure to use onboard wifi ?
    3) Can I declare multiple SSIDs, associated with different VLANs on this model?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    HI @Spootzy ,
    You can download the latest firmware for the USG20W-VPN (version 5.38(ABAR.0)C0) from the Zyxel Download library
    1. You can establish a secure site-to-site IPSec VPN tunnel (with USG60)
    2. You can use the WPA2 with a password to secure your built-in AP's SSID.
    3. You can add multiple SSIDs; however, they cannot be associated with different VLANs.
    For more details, please refer to the USG20W-VNP User Guide
    Zyxel_Judy
    Untitled Image
