NWA90AX - Firmware 7.00(1) change of logformat AGAIN
How many times do I have to CLEARLY state NOT to change the logformat, or AT LEAST include it in the flippin' changelog?
You changed your logformat AGAIN!!!!
You removed the year from the date:
before: Jul 18 22:00:02 2024 NWA90AX
after: Jul 18 22:00:02 NWA90AX
and you added an unintentional space between source ip and port:
before: src="0.0.0.0:0" dst="0.0.0.0:0"
after: src="0.0.0.0: 0" dst="0.0.0.0:0"
Hi @DevSport
We have previously addressed the syslog format issue based on user feedback and made adjustments in the latest firmware release. You can find more details in the bug fix section of the release note:
Regarding your concerns,
According to RFC specifications, the log format should not include the year. This change was implemented to align with these standards.
We could not replicate the issue with the space between the IP and port on our end. This might be a display behavior of your syslog server. Could you please capture the syslog packet via Wireshark from your end to verify if the space is present? Below is a sample capture from our NWA90AX (V7.00(ACCV.1)C0) that does not show this issue.
Kay
Hi @DevSport
Kay
- 441 Beta Program
- 210 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
