Site to site Route-based and Policy-based to same IP link issue
PeterUK
PeterUK Posts: 4,415 image  Guru Member
edited July 2024 in USG FLEX H Series
USG FLEX200HV1.21(ABWV.0)
setup is USG60W
LAN2 192.168.254.9 255.255.255.248
Gwtoflex200H_local2 Site-to-site with Dynamic Peer
Pre-Shared Key 123456789
Phase 1 AES128 SH1 DH2
local policy192.168.252.0/23
remote policy192.168.255.64/28
Phase 2 AES128 SH1 DH2
VTI_test
IP 192.168.254.10
Phase 1 AES128 SH256 DH2
VTI IP 192.168.255.43 255.255.255.240
FLEX200H
Ge3 WAN3 192.168.254.10 255.255.255.248 gateway 192.168.254.9
P4 VLAN47 192.168.255.39 255.255.255.240
P4 VLAN48 192.168.255.65 255.255.255.240
TuneltoUSG60W_local3 Site-to-site Policy-based
Pre-Shared Key123456789
local policy192.168.255.64/28
remote policy192.168.252.0/23
Nailed-up
VTI Route-based
IP 192.168.254.9
VTI IP 192.168.255.42 255.255.255.240
Nailed-up
So here is what happens disable Gwtoflex200H_local2 on USG60W and connect the VTI Route-based on FLEX200H connects fine then enable Gwtoflex200H_local2 and connect TuneltoUSG60W_local3 Site-to-site Policy-based it connects fine but if I disable VTI on Flex200H then enable it the VTI does not connect until you disable Gwtoflex200H_local2 and start over.
    edited July 2024 Answer ✓
    Ok solved it on how you can do this after testing with USG60W to FLEX200 the above don't work so there are two ways One is to have one IKEv1 and the other IKEv2 or if you want both IKEv2 you have the mismatch both Phase 1 and Phase 2 like I only did Phase 1 at the start.
    VTI Route-based
    Phase 2 AES128 SH256 DH2
    Tested between USG60W and FLEX200H with ping
    VTI Route-based
  • Zyxel_Kay
    Hi @PeterUK
    Could you please share the IKE logs from both devices so we can investigate further?
    Kay
    Hi Kay
    I solved it as said above
