I have 2 MSSID profiles that are identical and would like to delete one
Hi @michaelstaylor ,
As @PeterUK mentioned, you can click on the name it will drop down a list for disable.
Please note that the Radio 1 setting is for the 2.4GHz band, and the Radio 2 setting is for the 5GHz band. If you disable one of them, the SSID will only be broadcasted on the remaining band.
Zyxel_Judy
I have 2 MSSID profiles and would like to delete one as they are redundant
They're not exactly the same, but 2 of the same. Is there a way to delete one?
if you right click on the name it will drop down a list for disable
That did it…Thank you!!!!
Zyxel_Judy
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
