I have 2 MSSID profiles that are identical and would like to delete one
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,347 image  Zyxel Employee
    Hi @michaelstaylor ,
    As @PeterUK mentioned, you can click on the name it will drop down a list for disable.
    Please note that the Radio 1 setting is for the 2.4GHz band, and the Radio 2 setting is for the 5GHz band. If you disable one of them, the SSID will only be broadcasted on the remaining band.
    Zyxel_Judy
    Untitled Image
  • michaelstaylor
    michaelstaylor Posts: 7
    edited July 2024
    I have 2 MSSID profiles and would like to delete one as they are redundant
  • michaelstaylor
    edited July 2024
    They're not exactly the same, but 2 of the same. Is there a way to delete one?
    PeterUK Posts: 4,446 image  Guru Member
    edited July 2024
    if you right click on the name it will drop down a list for disable
  • That did it…Thank you!!!!
  • Zyxel_Judy
    Zyxel_Judy
    Untitled Image
