Port forwarding problem USG60
Hello. I have USG60 with LAN1 IP 192.168.1.1 and switch GS1920 after firewall with IP 192.168.1.2. I try to make port forwarding to access switch configuration from outside. I make all from this site https://support.zyxel.eu/hc/en-us/articles/360001390934-NAT-Rule-Configuration-on-a-USG-Port-Forwarding- but my forwarding cannot work. In my case i ask to forward outside port 8082 to 192.168.1.2:80 (web acsess on switch). I try to make connection (WAN1-IP):8082 but that not work. When i see log i find this: (WAN1-IP):8780 to 192.168.1.2:80 ACCESS BLOCK. Next time outside port are changes. For example - (WAN1-IP):8820 to 192.168.1.2:80 ACCESS BLOCKED. Every time when i try to make this connection source port are different and access are blocked because source port are not 8082. What are reason for that? Every time i ask port 8082 but log write other. I will be very thankful for every support.
That is log information.
Have you made a firewall rule to allow WAN to LAN?
Yes. And here are the problem. I find mistake. When i make new Object with port i write port 8082 (external port) but i must add port 80 (internal). And in Policy Control rule i write Service - HTTP (port 80) and all is done. Case is closed. It is my mistake but in all documents or videos i see port forwarding who are with same numbers for external and internal ports and that is difference. When i make rule i include external port but correct are to include internal port in Service Section. I hope all will understand that who explain.
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 922 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 989 Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 140 Service & License FAQ
- 72 About Community
- 62 Security Highlight
