The admin web interface for the router is taking forever and not loading. Outage?
Cittycool
Cittycool Posts: 1 image  Freshman Member
Also the boosters are not working, they are connected but not boosting. When actually using the main router it seems to work fine though.
I can only think that if the admin thing isn't working it might affect how it connects?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,316 image  Zyxel Employee
    HI @Cittycool ,
    Could you share which "booster" and "main router" models you are using?
    We assume the issue is that you can't connect to the local web interface. Could you provide a screenshot?
    Also, please share details about the problems with the "boosters". What specific symptoms are you experiencing?
    Zyxel_Judy
    Untitled Image
