XGS4600 restore config
PMD
PMD Posts: 1
We have Zyxel XGS4600-32F switches and like to test the restore but it doesn't work. I get "Syntax error, Line 5 vlan 1". Anyone know what ths is due to?
/PD
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,611 image  Zyxel Employee
    edited August 2024 Answer ✓
    Hi @PMD,
    I would like to check with you:
    1. Could you share the config file with me? I will help to check this issue. I will DM you for the request.
    2. What is your current firmware version?
    3. What firmware version did you back up this config file?
    Update: This issue was fixed in V4.60(ABBH.0)C0. If anyone has a similar issue, please upgrade to the latest firmware version.
    Zyxel Melen
  • Zyxel_Melen
    Hi @PMD,
    Zyxel Melen
