MG-108
No, it's an unmanaged switch so it's not possible to configure VLANs.
A managed switch like the GS1200 series will give you VLAN support.
MG100 Series - 5/8-Port 2.5GbE Unmanaged Switch - Specifications | Zyxel Networks
GS1200 Series - 5-Port/8-Port Web Managed Gigabit Switch - Overview | Zyxel Networks
I need something with at least six to eight 2.5gb (I could do 10gb as well) ports. I don't need a SFP port. I don't see anything with those specs from Zyxel.
Well, I kind of solved my own problem. The MG-108 does support vlan passthrough, that's all I needed. I had a Trendnet switch between my AP and it. I guess the Trendnet does not support vlan passthrough. I removed it from the path and now the vlan's are making it to my router/firewall. No need for a managed switch.
George
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
