converting dmz to LAN3 ?
Aballo
Aballo Posts: 19 image  Freshman Member
We've got a Flex 200 and would like to get a LAN3: is it possible ?
Is there exist an alternative if not ?
Many thank's
L.
    PeterUK Posts: 4,264 image  Guru Member
    Yes it just be that instead of LAN3 for the zone it be DMZ for the zone.
    edited July 2024
    You can treat DMZ as LAN3 but the zone is DMZ you can still route DMZ to other LAN's and LAN's to DMZ by policy control.
    Or you can VLAN
  • Aballo
    Thank's for your answer.
    Does P7 can be use as LAN3 ?
    L.
