NWA50AX connected to a USG FLEX 50 (USG20-VPN)
Jeff_ATS
Jeff_ATS Posts: 11 image  Freshman Member
I have added two NWA50AX APs to my USG FLEX 50 (USG20-VPN). I have them connected to my DMZ port and are working fine. I can monitor DHCP Status and see devices connection but I have no access to manage/connect to the APs. I would prefer not to use Nebula and only want to access through a web browser. My desktop is 192.168.1.141 and my DMZ network is 172.20.2.xxx. Do I need to add a route?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @Jeff_ATS,
    Could you help to check if your security policy has this policy?
    If yes, your problem is that the current policy only allows the service "Default_Allow_DMZ_To_ZyWALL". Please change the service of this rule from "Default_Allow_DMZ_To_ZyWALL" to "any" and check.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Jeff_ATS,
    Zyxel Melen
